See my post below for more info!
Topic number – GI01.30-P-058933
Date – 03-22-2017
Validity – All models with engine 651
Complaint
– Slight coolant loss between coolant connection fitting (jam_rs edit: in layman’s terms, fuel filter housing!) and cylinder head.
– Coolant warning in instrument cluster
Cause
Sealing surface of coolant connection fitting may leak under operation because of boost pressure fluctuations.
Remedy
Replace coolant connection fitting with seal. It is absolutely essential to install the coolant connection fitting together with the new seal provided, and to tighten the bolts in the sequence below.
The use of lubricant and sealing agent is not permitted!
– Tighten the two bolts for the two-hole flange on the cylinder head first to 10 Nm.
– Then tighten the three bolts for mounting onto the intake manifold with 8.5 Nm.
– Fill and bleed the cooling system in accordance with the TIPS document of Group 20.10 “Diagnostic aid for coolant loss in engine 651”.
Note:
The coolant connection fitting should be mounted onto the charge air manifold under tension, because the charge air manifold will move upwards when boost pressure is applied.
Symptoms
Power generation / Engine cooling system / Indicator lamp / Illuminates yellow
Power generation / Engine cooling system / Function / Coolant level too low
Power generation / Engine cooling system / Display message / Coolant – Serviced Required
Parts
A 651 200 39 00 Water outlet nipple parts kit 1 X
A 651 142 24 80 Metal seal for EGR cooler 1 X
