Key not recognised and/or shifts to P before stopping – GI54.25-P-056391
Topic number – GI54.25-P-056391
Date – 01-17-2014
Validity – Model series 166, 204 (GLK only), 212, 218, 246 with automatic transmission
Complaint
The key is not recognized in the electronic ignition switch, the vehicle cannot be started and/or the automatic transmission shifts to “Automatic P” at speeds below 6 km/h.
Cause
A combination of incorrect adhesive, height of the adhesive and height of the chip on the diodes of the “key inserted” detector in the electronic ignition switch (EZS) results in a transition resistance at the diodes of the key detector. The key is detected as “not inserted” and the “Automatic P function” is performed.
Not OK as of production date 05/2012
OK as of VIN
166 … *A206996
204 … *G103135
212 … *A776831
218 … *A090383
246 … *J153923
246 … *N051707
Remedy
Replace electronic ignition switch. Before replacing, perform the guided test of the drive authorization system!
